网上看到一个办法,不知道还管用不,楼主试试,再告诉我们结果
- Obtain a copy of the original RC1 pkeyconfig file, and replace the current file in C:\Windows\System32\licensing\pkeyconfig with it.
1.获取RC1的pkeyconfig文件,用它来替换当前的C:\Windows\System32\licensing\pkeyconfig
- If you don't have permission to overwrite the file you'll need to take full control of the file, to do this:
2.如果没有替换权限,你可以这样做
-> right-click Properties, browse to the Security tab, click on Advanced, locate the Owner tab, click Edit, select your username, then click OK. You'll be prompted with a screen that says "If you have just taken ownership of this object, you will need to close and reopen this objects properties before you can view or change permissions" just click OK. Now, click Edit, select your username, and click Full Control.
3.(如何获得替换权限,我就不翻译了)
- You'll need to obtain a fresh key from Microsoft which you can register and get from the CPP website -> http://go.microsoft.com/fwlink/?linkID=67708
4.你需要到http://go.microsoft.com/fwlink/?linkID=67708申请一个新的KEY(应该是RC1的KEY,免费的)
- Do yourself a favour and disable Automatic Updates.. Now, reboot into Safe Mode
5.禁用自动更新,然后重启进入安全模式
- Now we want to kill the WPA encrypted store. Delete the following (hidden) files:
-> "C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0"
-> "C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0"
6.删除下面两个隐藏文件
- Uninstall the WGA update. Run the following command: regsvr32 /u c:\windows\system32\LegitCheckControl.dll
7.为删除WGA更新,运行如下命令:regsvr32 /u c:\windows\system32\LegitCheckControl.dll
- Replace the tokens.dat in C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing with the original RC1 file.
8.用RC1的tokens.dat 替换当前C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing
- Run regedit, and locate HKEY_LOCAL_MACHINE\SYSTEM\WPA
9.运行regedit,定位到HKEY_LOCAL_MACHINE\SYSTEM\WPA
- Remove the WPA key to remove it and the subkeys under it.
10.删除WPA键及其子键
- Close regedit and reboot Vista normally.
11.关闭regedit后重启Vista
- When you log on you will be in RFM and told "Your copy of windows is not genuine"
12.当你登录后会变成RFM并且被告知"你的windows不是正版"
- Run slui.exe, enter your CPP product key. It should activate as genuine! Log off and back on to get Aero back.
13.运行slui.exe,输入你CPP产品KEY.它就会激活为正版! 注销重启进入,找回Aero. |
