[VISTA求助] 2G内存装vista旗舰难道还不够?
发表于 2007-2-2 09:14:00
我昨天也装了升级补丁,难道会影响速度吗?
发表于 2007-2-2 09:23:00
关闭一些特效试试,vista对显卡要求比较高。
发表于 2007-2-2 09:25:00
Ok guys, I have make some simple research about CPU works on vista. everybody know RAM should has at least 1GB, but how about CPU? Among 3 processors tested. DAMN, i forgot to look on the Index score.
AMD sempron 2800+ (default clock), + 2GB Gskill DDR 500
AMD sempron 2800 @ 2.34GHz + 2GB Gskill DDR 500
Pentium M 1.7GHz, + 1GB + 256MB = 1280MB DDR2 533
Core Duo T2050 1.66GHz. + 1GB DDR2 533
How we test? my friend and me test it by 1 day-using feeling. I knew this kind of measurment of the performance by justice 'feeling' is suck and unprofessional but for us... JUST FOR FUN. We gives the rating for each CPU after 1 day-using feeling. We installed the driver, same applications, same updates, with AERO disabled, same sidebar gadgets, same office 2007, Klite codec 1.63, watching DVD, run the kaspersky 614 final built, Messenger 8.1, webcam + chatting, google earth, skype and google earth. All done with clean install of vista ultimate RTM and without any cracks as just for CPU evaluation.
The best is Core Duo T2050. Although it just has 1.66GHz but it can derive a good performnce. We can conclude vista work VERY HAPPILY on Duo Core or even Quad Core. With single core, your CPU will over tired to process so much background processing.
We overclock the AMD sempron to the max, nothing can feel from it.. still very lagging due to only 256l L2 cache hence it is single core only. Even PM 1.7Ghz with 2MB l2 cache can work par on the ratio of performance. The suck is AMD sempron 2800 with default clock speed. Although it has 2gb ram but AMD cant work corporate with it. It cant fully explode the potential of 2GB DDR 500 performance.
发表于 2007-2-2 09:29:00
disable the aero will help... and fogot to mention, we tested AMD sempron 2800 is works on 7600GT, the performance still cant beat Core duo T2050
发表于 2007-2-2 09:38:00
o, my god! do i must change my cpu?
发表于 2007-2-2 09:40:00
2L CACHE的重要性终于体现出来了.
发表于 2007-2-2 09:45:00
AMD 64 has 1MB l2 cache and i believe it still good. no need to buy a duo core CPU as your graphic is only 9550. Unless your have at least 7600GS or above. Try to overlock AMD 64, and almost all the AMD 64 can be easily overclocked on a good motherboard, unless your motherboard is totally cheap one which dun have overclock feature.
发表于 2007-2-2 09:49:00
my matheboard is asus k8v-x
发表于 2007-2-2 09:58:00
seems asus is likely to support the overlocking, then why dun try it by increase the HTT value...? and make sure you monitor the temperature and you might need a benchmark utilities like 3D mark, PC mark, sisoft sandra, super pi, sciencemark, to test the system stability after overclock the CPU. and also ensure you have good PSU.
发表于 2007-2-2 10:02:00
出现问题应该分析原因的所在,不要一概的怪内存!1GB的内存已经完全可以胜任VISTA普通用户的使用!
