存在问题
紫光5.0.0.5076 (IE有兼容问题)
迅雷 (初次使用一切正常,但之后几天会出现IE内无法下载)
刻录软件
Ahead Nero v7.2.0.3b (32Bit) [NOTE: Internal Error - Fails to install properly, but program works]
压缩软件
PKZIP v8.00.0026 (32 Bit) NOTE: Must run program in 'Windows XP SP2 Compatibility Mode' AND must run program 'As Administrator'
游戏
实况9没有声音
City of Heroes (32 Bit) [NOTE: To have the game function, must change to XP video drivers, thus sacrificing Aero effects.] (on Nvidia, untested on ATI)
图像处理
Corel Suite X3 X3 (32 Bit)经测试,可以安装,不能运行。提示少msxml4。dll,其实这个文件是有的,在system32下。但在64位vista下一切正常当然在Program Files(x86)下
Adobe Photoshop CS2 v9.0.2 (32 Bit & 64 Bit) Note: Adobe Updater fails on many components, some appear to be updated however. Manually download and install updates for best results.
AutoDesk Architectural Desktop 2006(32 Bit) Note: Gets through the install fine. Then for some reason it has trouble dealing with the new "Appdata" directory structure. Errors upon initial use stating that it can't locate certain program files. In order to correct this, while in the program go to options->files and manually redirect the program to the correct paths.
播放器
Philips Media Manager Software v3.3.12 [NOTE: Incompatible with AERO - Vista drops to 'Basic' mode.]
聊天工具
Microsoft Office Communicator v1.0.559 (32 Bit) [Note: Random crashes]
Trillian v3.1 build 121 (32 Bit) Need to disable av.dll in plugins.ini for Aero Glass to work - instructions
Miscellaneous
VMWare Workstation v5.5.2 (32 Bit) [Note: Unsigned Driver install warning. Must run as Administrator for full functionality.]
Pixeur v.2.7.08 [NOTE: Must run 'As Administrator' and in 'Windows XP SP2 Compatibility Mode']
PostCast Server Professional v3.0.58 [NOTE: Must run 'As Administrator' and in 'Windows XP SP2 Compatibility Mode']
存在严重问题
杀毒软件
eset nod32防毒软件存在问题
Avast! Home Edition v4.7 (32 Bit) [NOTE: A service is blocked by Vista.]
AVG Anti-Virus Free v7.1.405 (64bit) Installer refuses to install on 64bit
刻录软件
Ahead Nero v7.2.3.2b (32Bit) [NOTE: Internal Error - Fails to install properly, fails to start program]
Ahead Nero v7.2.7.0 (32Bit) [NOTE: Internal Error - Fails to install properly, fails to start program]
Daemon Tools v4.0.3 x86 (Vista says incompatible and won't execute setup)
SlySoft Virtual CloneDrive v5.1.4.5 (64 Bit) [NOTE: Installation file is not launching saying it won't run on the operating system.]
Defragmenting
PerfectDisk 8.0 Build 30 [NOTE: Will extract installer but then say incompatible os]
Developer Tools
Microsoft Expression Web Beta 1 (64 Bit) [NOTE: Error during setup.]
Subversion
TortoiseSVN
BT
Azureus (Java 6 beta 2) Error JVM could not be started. The main method may have thrown an exception. (PLEASE CHECK VALIDITY)
游戏
街头篮球
天堂2
完美世界
Colin McRae Rally 2005 (64 Bit) [NOTE: The game doesn't launch saying it's not compatible with the OS.]
Command & Conquer (64 Bit) [NOTE: Fails to install, incompatible.]
Command & Conquer Red Alert (64 Bit) [NOTE: Fails to install, incompatible.]
SimCity 4 (64 Bit) [NOTE: Game fails to start due to not detecting cd in drive.]
播放器
foobar 0.9.3以下版本存在问题
Auto Gordian Knot v2.32b (32 Bit) [NOTE: Installs fine but crashes on launch.]
BSplayer v2.00 Pro Build 937 (32 Bit) [NOTE: Can't display video.]
Linkman v6.8.0.79 (32 Bit) [NOTE: I have it installed but it won't start in Vista, though it worked fine in XP/SP2 without installing.]
Mp3Tag v2.36 (64 Bit) [NOTE: Installs fine but says it's missing memory when you try to run it.]
TMPGEnc Plus 2.5 (32 Bit) install fine, freeze when open new project or browes for files.
聊天工具
windows livemail beta (latest build with rhaspody support) ideas.live.com
Miscellaneous
Diskeeper Professional Premier v10.0.606 [NOTE: Refuses to install; says unsupported Operating System.]
Symantec/Norton Partition Magic v8.0 [NOTE: Will install but once installed will not run; says unsupported Operating System.]
Microsoft SideWinder Game Controller Software 4.0 [NOTE: Doesn't install at all, Windows Vista silently refuses GCS.] |
