<FONT size=3>电脑使用中或开机关机出现这些英文就死机,是什么原因?<BR>A problem has been detected and windows has been shut down to prevent damage to you commputer.<BR>KERNEL_STACK_INPAGE_ERROR 或 KERNET_DATA_INPAGE_ERROR<BR>If this is the first time you have seen this stop error screen, restart your computer.If this screen appears again,follow these steps:<BR>check to make sure new hardware or software is properly installed.<BR>If this is a new installation,ask your hardware or software manufacturer for any windows updates you might need.If problems comtinue,disable or remove any newly installed hardware or software.Disable BIOS memory options such as caching or shadowing.If you need to use safe Mode to remove or disable components,restart your computer,press F8 to select Advanced stavtup optioms,and then select safe mode .Technical information。<BR>***stop: oxoooooo.....等一些字符</FONT> <BR> |
