cleanmgr.exe > Disk Cleanup, popular with Windows 98 磁盘清理
cliconfg.exe > SQL Server Client Network Utility SQL客户网络工具
clipbrd.exe > Clipboard viewer for Local will allow you to connect to other clipboards 剪贴簿查看器
clipsrv.exe > Start the clipboard Server 运行Clipboard服务
clspack.exe > CLSPACK used to create a file listing of system packages 建立系统文件列表清单
cluster.exe > Display a cluster in a domain 显示域的集群
_cmd_.exe > Famous command prompt 没什么好说的!
cmdl32.exe > Connection Manager Auto-Download 自动下载连接管理
cmmgr32.exe > Connection Manager 连接管理器
cmmon32.exe > Connection Manager Monitor 连接管理器监视
cmstp.exe > Connection Manager Profile Manager 连接管理器配置文件安装程序
comclust.exe > about cluster server 集群
comp.exe > ComClust Add, Remove, or Join a cluster. 比较两个文件和文件集的内容*
compact.exe > Displays or alters the compression of files on NTFS partitions. 显示或改变NTFS分区上文件的压缩状态
conime.exe > Console IME IME控制台
control.exe > Starts the control panel 控制面板
convert.exe > Convert File System to NTFS 转换文件系统到NTFS
convlog.exe > Converts MS IIS log files 转换IIS日志文件格式到NCSA格式
cprofile.exe > Copy profiles 转换显示模式
cscript.exe > MS Windows Scripts Host Version 5.1 较本宿主版本
csrss.exe > Client Server Runtime Process 客户服务器Runtime进程
csvde.exe > Comma Separated Variable Import/Export Utility 日至格式转换程序
dbgtrace.exe > 和Terminal Server相关
dcomcnfg.exe > Display the current DCOM configuration. DCOM配置属性
dcphelp.exe > ?
dcpromo.exe > Promote a domain controller to ADSI AD安装向导
ddeshare.exe > Display DDE shares on local or remote computer DDE共享
ddmprxy.exe >
debug.exe > Runs Debug, a program testing and editing tool. 就是DEBUG啦!
dfrgfat.exe > Defrag FAT file system FAT分区磁盘碎片整理程序
dfrgntfs.exe > Defrag NTFS file system NTFS分区磁盘碎片整理程序
dfs_cmd_.exe > configures a Dfs tree 配置一个DFS树
dfsinit.exe > Distributed File System Initialization 分布式文件系统初始化
dfssvc.exe > Distributed File System Server 分布式文件系统服务器
diantz.exe > MS Cabinet Maker 制作CAB文件
diskperf.exe > Starts physical Disk Performance counters 磁盘性能计数器
dllhost.exe > dllhost is used on all versions of Windows 2000. dllhost is the hedost process for all COM+ applications. 所有COM+应用软件的主进程
dllhst3g.exe >
dmadmin.exe > Disk Manager Service 磁盘管理服务
dmremote.exe > Part of disk management 磁盘管理服务的一部分
dns.exe > DNS Applications DNS
doskey.exe > recalls Windows command lines and creates macros 命令行创建宏
dosx.exe > DOS Extender DOS扩展
dplaysvr.exe > Direct Play Helper 直接运行帮助
drwatson.exe > Dr Watson for 2000 Fault Detector 华生医生错误检测
drwtsn32.exe > Dr Watson for 2000 viewer and configuration manager 华生医生显示和配置管理
dtcsetup.exe > Installs MDTC
dvdplay.exe > Windows 2000 DVD player DVD播放
dxdiag.exe > Direct-X Diagnostics Direct-X诊断工具
edlin.exe > line-oriented text editor. 命令行的文本编辑器(历史悠久啊!)
edlin.exe > line-oriented text editor. 命令行的文本编辑器(历史悠久啊!) |
