我拿本子当台式机用的,vista系统,自动更新(好像为显驱)后不到一小时出现花屏反应,每次花屏时间不到1分钟便自动恢复,10分钟内将近三到四次,随之类似死机,无法响应,重启依旧。
数小时后,疑为显卡驱动更新所致,再次开机,进安全模式,进入不到三分钟,再次花屏…隔天,进入安全模式后,还原系统,操做间无花屏现像;随之重启,正常进入系统,一切正常,五分钟后,全屏小浮度花屏产生,机器反应开始迟缓,黑屏,三分钟后,蓝屏,显现错误如下:
A problem has been detected and windows has been shut down to prevent damage to your computer.
The system encountered an uncorrectable hardware error.
If this is the first time you're seen this stop error screen,restart your computer.If this screen appears again,follow these steps:
Check to make sure any new hardware or software is properly installed,if this is a new installation,ask your hardware or software manufacturer of any windows updates you might need.
If problems continue,disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing.If you need to use safe Mode to remove to remove or disable components,restart you computer,press F8 to select Advanced Startup Options,and then select Safe Mode.
Thchnical information:
***STOP:0×00000124(0×00000000,0×85DA9028,×F2000040,0×00000800)
Collecting data for crash dump…
Initializing disk for crash dump…
Beginning dump of physical memory.
Dumping physical memory to disk:100
Physical memory dump complete.
Contact your system admin or technical support group for assistance.
这到底是硬件故障还是软件冲突~ 请高手帮忙诊断解决,先谢谢了~~ |
