[转]Biostar TForce P965 Deluxe - 530FSB 1:1 4-4-3-4
Rank: 2
发表于 2006-8-16 09:03:00
After few crappy bios versions Biostar finally managed to fix the overclockability issue(s) of TForce P965 Deluxe board.
The previous versions couldn´t run over 405FSB no matter what setting were used.
With the newest beta bios the problem pretty much... dissapears
CPU-Z validation
Tomorrow I´ll try the 32M calculation and higher frequencies.
Now it is the right time to take couple glasses of Glenfiddich 21yo
The stock MCH heatsink of the board is pretty insufficient.
IIRC the same heatsink was used on Asus A7N8X (nF2) boards, so go and figure what I mean when I say insufficient...
I replaced the original chipset heatsink with MCX-159R from Swiftech.
The MCX-159R is barely warm while the original gave me burn marks with 1.7V voltage.
The mosfets of cpu power cirquit can also run pretty hot if you are using water cooling or heatsink which have vertically mounted fan (like Tuniq Tower 120, Scythe Ninja, CNPS9500 etc) (= no airflow for the mosfets).
My Fluke IR thermometer displayed 67c temperature with 1.45V vcore while the cpu was in idle state. After adding A记爱好者 for the mosfets, their temperature dropped to 42c (loaded).
I´m sure that Biostar knows this problem since there are mounting holes for the mosfet heatsink.
发表于 2006-8-16 09:31:00
新bios较之前的bios极大提升了oc性能
这么重要的消息没人关注? P965+ICH8R
发表于 2006-8-16 10:28:00
一直在关注这款板子,可惜南北桥的散热不行,自己改装的话成本高了不少
发表于 2006-8-16 10:46:00
这个早转过了,当时没人理,这还是1gX2的 K
发表于 2006-8-16 11:02:00
值得关注.对T系列有不错的印象.而且还是4M的版本,1G*2 内存, ICH8R
发表于 2006-8-16 12:56:00
这板子好像是台湾没上市  才没火  国外好像很火的
发表于 2006-8-16 14:23:00
我也早就注意到了这个板子, 只是好象找不到什么评测之类的
发表于 2006-8-16 14:38:00
呼唤小白啊!板子貌似1.2k
发表于 2006-8-16 17:37:00
关注一下.........
发表于 2006-8-16 17:54:00
原帖由 自自在在 于 2006-8-16 14:38 发表
呼唤小白啊!板子貌似1.2k
等我975xbx出了 弄张玩玩
