PARADOX成功激活英文版VISTA ULTIMATE
与你分享的快乐胜过独自拥有!
有关这个版本的VISTA ULTIMATE,各位可以在论坛的搜索中键入“PARADOX”就可以找到相关的链接和下载,有HTTP和BT两种方式
今天很高兴,我终于抛弃了VISTA ENTERPRISE EN版, 下午重新安装了PARADOX提供的VISTA ULTIMATE 英文版,按照提示一步一步激活了VISTA ULTIMATE,显示为OEM版本,我的笔记本是THINKPAD,现在已经完全不需要修改BIOS了,我挺高兴的.是真正的激活.步骤如下:
1. Install the Windows Vista x86 edition of your choice without entering any product key during setup.
Basically any Windows Vista x86 installation media will do, regardless if it's MSDN/Retail/OEM/...,
MSDN/Retail are recommended though.
提示:安装到要输入序列号的时候---千万不要输入任何序列号!!!!!!,这点很重要
important issues:
第一个步骤:RUN OEMTOOL (文件在PARADOX的400多k的附件包里),选择一个你要使用的OEM厂家版本,比如华硕,比如联想LENOVO,比如ACER,看你喜欢哪一个了,有关哪个厂家有提供ULTIMATE,文档里面都有说明,应该就只有ASUS和HP。
第二个步骤:关闭VISTA的UAC功能
原文:Most operations described below require elevated privileges, so disabling UAC (Run->MSCONFIG.EXE->
Tools->Disable UAC) for the time being is recommended, Of course, it can be safely re-enabled after
all steps have been performed. Otherwise OEMTOOL.EXE and some SLMGR.VBS operations must be explicitly
run with adminstrative privileges.
简译:安装完毕后的第一件事情是首先应该先关闭掉UAC, 在START SEARCH里直接键入 MSCONFIG,然后在TOOL选 DISABLE UAC ,然后点击右下的LAUNCH,重新启动计算机。下面的步骤跟大家平常看到的OEM 激活并无二致,
2. Install the emulation driver.
Run OEMTOOL.EXE, select the OEM BIOS information to emulate (ASUS might be a good choice given the
fact that it's the only OEM for which a complete set of product keys is provided ;)) and hit the
'<Install Emulation Driver>' button.
Alternatively you can just right-click the ROYAL.INF file and chose 'Install' from the appearing
menu. This only allows for installing the default OEM BIOS information (ASUS) though and is strongly
discouraged unless OEMTOOL.EXE fails for some unknown reason.
When prompted about whether to install an unsigned driver, allow it.
(For some odd reason Microsoft didn't wanna sign this one...;))
3. Reboot your machine.
4. Install the OEM certificate matching your OEM selection during driver installation by running
SLMGR.VBS -ilc <OEMNAME>.XRM-MS
(e.g. "SLMGR.VBS -ilc C:\ASUS.XRM-MS" if you chose to install the default driver and extracted
the certificate file to C:\)
Note that this operation might take quite a while depending on your system, so be patient.
5. Install an OEM product key matching the installed edition of Windows Vista x86 by running
SLMGR.VBS -ipk <OEM_PRODUCT_KEY>
(e.g. "SLMGR.VBS -ipk 6F2D7-2PCG6-YQQTB-FWK9V-932CC" if you're running Windows Vista Ultimate using
the default emulation driver)
See PKEYS.TXT for a list of OEM product keys published by different OEMs.
6. Run 'SLMGR.VBS -dlv' or right-click 'Computer' and chose 'Properties' to verify your licensing status.
IMPORTANT STEP:
一切步骤非常简单,看着说明就可以激活,而且后面几个步骤根本不需要启动电脑。PARADOX的发明者来自国外,似乎是欧洲,署名是: TEAM PARADOX。
下面这张图是我激活的截图:
各位,我已经成功了激活了ULTIMATE EN ,而且也UPGRADE了。
其他人有放这个PARADOX 激活工具:
链接点击此处:http://www.vistafans.com/thread-112029-1-2.html |
