可是microsoft不是这么说的,用upgrade DVD是不能clean install的。
[url=http://support.microsoft.com/default.aspx/kb/930985/en-us][/url]
You cannot use an upgrade key to perform a clean installation of Windows Vista
View products that this article applies to.
Article ID : 930985
Last Review : January 19, 2007
Revision : 1.0
On This Page
SYMPTOMS
You purchase an upgrade key for Windows Vista. Then, you try to use the upgrade key to perform a clean installation of Windows Vista by starting from a Windows Vista DVD. However, Windows Vista does not let you perform a clean installation by using the upgrade key, and you cannot upgrade to Windows Vista.
Back to the top
CAUSE
This problem occurs because Windows Vista does not check upgrade compliance. Therefore, you cannot use an upgrade key to perform a clean installation of Windows Vista.
Back to the top
RESOLUTION
To resolve this problem, use one of the following methods.
Back to the top
Method 1
Upgrade to Windows Vista from an earlier, supported version of Windows that is already installed on the computer.
Back to the top
Method 2
Purchase a license that lets you perform a clean installation of Windows Vista. |
