关于Cell在Folding@home的成绩……FAQ introduces the issue fairly clearly:
What type of calculations the PS3 client is capable of running? The PS3 right now runs what are called implicit solvation calculations, including some simple ones (sigmodal dependent dielectric) and some more sophisticated ones (AGBNP, a type of Generalized Born method from Prof. Ron Levy's group at Rutgers). In this respect, the PS3 client is much like our GPU client. However, the PS3 client is more flexible, in that it can also run explicit solvent calculations as well, although not at the same speed increase relative to PC's. We are working to increase the speed of explicit solvent on the PS3 and would then run these calculations on the PS3 as well. In a nutshell, the PS3 takes the middle ground between GPU's (extreme speed, but at limited types of WU's) and CPU's (less speed, but more flexibility in types of WU's) [emphasis added].
I'll also point you to another section of the FAQ:
The GPU client is still the fastest, but it is the least flexible and can only run a very, very limited set of WU's. Thus, its points are not linearly proportional to the speed increase. The PS3 takes the middle ground between GPU's (extreme speed, but at limited types of WU's) and CPU's (less speed, but more flexibility in types of WU's). We have picked the PS3 as the natural benchmark machine for PS3 calculations and set its points per day to 900 to reflect this middle ground between speed (faster than CPU, but slower than GPU) and flexibility (more flexible than GPU, less than CPU). http://arstechnica.com/news.ars/ ... -fh.html?ntlfld.1.n
folding@home的Tflops还是说明不了什么啊
唉,要想有apples-to-apples的测试还是只能拿那些古董资料作参考
