买了张X800GTO的卡AGP的``驱动有些问题
开始装了自带的驱动,有花屏,就换了6.10版本的,但出现"you have chosen to install catalyst control center .The minimum. NET Framework version requied is 2.0.Please install before launching application."这一步已经解决了~!!!!
但是后面又跳出Setup did not find a driver compatible with your current hardware or operating system.Setup will now exit. 然后又跳出Setup was unable to complete the installation . Try to setup your display adapter with a standard VGA driver before running setup.
打字真累``高手帮忙解决下吧~~!! |
