《使命召唤2》安装后不能正常游戏?????
Rank: 2
发表于 2006-6-23 21:09:00
<P>我在安装完《使命召唤》后,点击图标,总是弹出这样的对话框:</P>
<P>Error during initialization:<BR>No valid rendering code path detected<BR>点“确定”后,又弹出一个对话框:</P>
<P>CoD2 1.0 build win-x86 Oct&nbsp; 6 2005<BR>----- FS_Startup -----<BR>Current language: english<BR>Current search path:<BR>E:\COD2\main\iw_14.iwd (2020 files)<BR>E:\COD2\main\iw_13.iwd (22624 files)<BR>E:\COD2\main\iw_12.iwd (510 files)<BR>E:\COD2\main\iw_11.iwd (733 files)<BR>E:\COD2\main\iw_10.iwd (970 files)<BR>E:\COD2\main\iw_09.iwd (1073 files)<BR>E:\COD2\main\iw_08.iwd (1363 files)<BR>E:\COD2\main\iw_07.iwd (3384 files)<BR>E:\COD2\main\iw_06.iwd (498 files)<BR>E:\COD2\main\iw_05.iwd (424 files)<BR>E:\COD2\main\iw_04.iwd (323 files)<BR>E:\COD2\main\iw_03.iwd (15 files)<BR>E:\COD2\main\iw_02.iwd (22 files)<BR>E:\COD2\main\iw_01.iwd (10 files)<BR>E:\COD2\main\iw_00.iwd (79 files)<BR>E:\COD2/main<BR>E:\COD2/raw<BR>E:\COD2/raw_shared<BR>E:\COD2/devraw<BR>E:\COD2/devraw_shared<BR>E:\COD2\main\localized_english_iw10.iwd (208 files)<BR>&nbsp;&nbsp;&nbsp; localized assets iwd file for english<BR>E:\COD2\main\localized_english_iw09.iwd (98 files)<BR>&nbsp;&nbsp;&nbsp; localized assets iwd file for english<BR>E:\COD2\main\localized_english_iw08.iwd (5 files)<BR>&nbsp;&nbsp;&nbsp; localized assets iwd file for english<BR>E:\COD2\main\localized_english_iw07.iwd (2 files)<BR>&nbsp;&nbsp;&nbsp; localized assets iwd file for english<BR>E:\COD2\main\localized_english_iw00.iwd (16 files)<BR>&nbsp;&nbsp;&nbsp; localized assets iwd file for english</P>
<P>File Handles:<BR>----------------------<BR>34377 files in iwd files<BR>execing default.cfg<BR>couldn't exec language.cfg<BR>========= autoconfigure<BR>configure.csv: using CPU configuration 2 GHz 256 MB<BR>execing configure.cfg<BR>configure.csv: using GPU configuration "*"<BR>Measured CPU speed is 2.42 GHz<BR>System memory is 248 MB (capped at 1 GB)<BR>Video card is "Intel(R) 82845G/GL/GE/PE/GV Graphics Controller"<BR>Streaming SIMD Extensions (SSE) supported</P>
<P>----- Client Initialization -----<BR>----- Initializing Renderer ----<BR>-------------------------------<BR>----- Client Initialization Complete -----<BR>----- R_Init -----<BR>Getting Direct3D 9 interface...<BR>Pixel shader version is 0.0<BR>Vertex shader version is 0.0<BR>Video card or driver doesn't accelerate transform and lighting.<BR>Video card or driver doesn't support high-quality polygon offset.<BR>Video card or driver doesn't support the required fixed-function texture blend operations.<BR>&nbsp; DirectX 7 rendering path will not be available.<BR>Video card or driver doesn't support direction lights in the fixed-function pipeline.<BR>&nbsp; DirectX 7 rendering path will not be available.<BR>Video card or driver doesn't support texture coordinate generation in the fixed-function pipeline.<BR>&nbsp; DirectX 7 rendering path will not be available.<BR>Video card or driver doesn't support enough texture coordinates for the DirectX 9 code path.<BR>&nbsp; DirectX 9 rendering path will not be available.<BR>Video card or driver doesn't support enough textures for the DirectX 9 code path.<BR>&nbsp; DirectX 9 rendering path will not be available.<BR>Video card or driver doesn't support enough hardware lights for the DirectX 7 code path.<BR>&nbsp; DirectX 7 rendering path will not be available.<BR>Error during initialization:<BR>No valid rendering code path detected.</P>
<P>&nbsp;</P>
<P>本人英语学的不是太好,看不懂是什么意思,拜托哪位大虾帮忙看下,谢谢!!!!</P>
发表于 2006-6-25 16:21:00
内存是248MB的&nbsp;&nbsp; 可是我一代也能玩啊&nbsp; 《魔兽争霸》也能跑
发表于 2006-6-26 05:55:00
8m的集成卡 你还是放弃吧
发表于 2006-6-23 22:11:00
<P>我用安装盘又修复了一下,可还是这样啊。。。。</P>
<P>还有啊,显卡是不是集成怎么看啊</P>
发表于 2006-6-23 22:16:00
Video card is "Intel(R) 82845G/GL/GE/PE/GV Graphics Controller‘<br>
<br>
这个就说了 你右键点 我的电脑 选属性 看看下面的内存是多少 <br>
如果不是256的整数倍 如480等 就是集成的了<br>
发表于 2006-6-23 21:40:00
八成是确文件了吧 <br>
再就是你的显卡 是集成的吧 那就别想跑这个游戏了 <br>
没有6600gt级别的显卡 想对付着玩都难<br>
发表于 2006-7-10 00:55:00
<P>去下载个补丁</P>
发表于 2006-8-28 21:23:00
<P>[QUOTE=dskends]八成是确文件了吧 <BR>再就是你的显卡 是集成的吧 那就别想跑这个游戏了 <BR>没有6600gt级别的显卡 想对付着玩都难<BR>[/QUOTE] </P>
<P>我的双128的5200+512内存,玩得还听流畅的啊</P>
发表于 2006-8-30 17:09:00
请用fps说话 <br>
<span ="lgText">使命召唤2 我用9800p 跑800*600都勉强30fps</span><br>
发表于 2006-11-20 21:51:17
提示: 作者被禁止或删除 内容自动屏蔽
