<P>我在安装完《使命召唤》后,点击图标,总是弹出这样的对话框:</P>
<P>Error during initialization:<BR>No valid rendering code path detected<BR>点“确定”后,又弹出一个对话框:</P>
<P>CoD2 1.0 build win-x86 Oct 6 2005<BR>----- FS_Startup -----<BR>Current language: english<BR>Current search path:<BR>E:\COD2\main\iw_14.iwd (2020 files)<BR>E:\COD2\main\iw_13.iwd (22624 files)<BR>E:\COD2\main\iw_12.iwd (510 files)<BR>E:\COD2\main\iw_11.iwd (733 files)<BR>E:\COD2\main\iw_10.iwd (970 files)<BR>E:\COD2\main\iw_09.iwd (1073 files)<BR>E:\COD2\main\iw_08.iwd (1363 files)<BR>E:\COD2\main\iw_07.iwd (3384 files)<BR>E:\COD2\main\iw_06.iwd (498 files)<BR>E:\COD2\main\iw_05.iwd (424 files)<BR>E:\COD2\main\iw_04.iwd (323 files)<BR>E:\COD2\main\iw_03.iwd (15 files)<BR>E:\COD2\main\iw_02.iwd (22 files)<BR>E:\COD2\main\iw_01.iwd (10 files)<BR>E:\COD2\main\iw_00.iwd (79 files)<BR>E:\COD2/main<BR>E:\COD2/raw<BR>E:\COD2/raw_shared<BR>E:\COD2/devraw<BR>E:\COD2/devraw_shared<BR>E:\COD2\main\localized_english_iw10.iwd (208 files)<BR> localized assets iwd file for english<BR>E:\COD2\main\localized_english_iw09.iwd (98 files)<BR> localized assets iwd file for english<BR>E:\COD2\main\localized_english_iw08.iwd (5 files)<BR> localized assets iwd file for english<BR>E:\COD2\main\localized_english_iw07.iwd (2 files)<BR> localized assets iwd file for english<BR>E:\COD2\main\localized_english_iw00.iwd (16 files)<BR> localized assets iwd file for english</P>
<P>File Handles:<BR>----------------------<BR>34377 files in iwd files<BR>execing default.cfg<BR>couldn't exec language.cfg<BR>========= autoconfigure<BR>configure.csv: using CPU configuration 2 GHz 256 MB<BR>execing configure.cfg<BR>configure.csv: using GPU configuration "*"<BR>Measured CPU speed is 2.42 GHz<BR>System memory is 248 MB (capped at 1 GB)<BR>Video card is "Intel(R) 82845G/GL/GE/PE/GV Graphics Controller"<BR>Streaming SIMD Extensions (SSE) supported</P>
<P>----- Client Initialization -----<BR>----- Initializing Renderer ----<BR>-------------------------------<BR>----- Client Initialization Complete -----<BR>----- R_Init -----<BR>Getting Direct3D 9 interface...<BR>Pixel shader version is 0.0<BR>Vertex shader version is 0.0<BR>Video card or driver doesn't accelerate transform and lighting.<BR>Video card or driver doesn't support high-quality polygon offset.<BR>Video card or driver doesn't support the required fixed-function texture blend operations.<BR> DirectX 7 rendering path will not be available.<BR>Video card or driver doesn't support direction lights in the fixed-function pipeline.<BR> DirectX 7 rendering path will not be available.<BR>Video card or driver doesn't support texture coordinate generation in the fixed-function pipeline.<BR> DirectX 7 rendering path will not be available.<BR>Video card or driver doesn't support enough texture coordinates for the DirectX 9 code path.<BR> DirectX 9 rendering path will not be available.<BR>Video card or driver doesn't support enough textures for the DirectX 9 code path.<BR> DirectX 9 rendering path will not be available.<BR>Video card or driver doesn't support enough hardware lights for the DirectX 7 code path.<BR> DirectX 7 rendering path will not be available.<BR>Error during initialization:<BR>No valid rendering code path detected.</P>
<P> </P>
<P>本人英语学的不是太好,看不懂是什么意思,拜托哪位大虾帮忙看下,谢谢!!!!</P>
<P>我的显卡是Intel 82845G 驱动程序日期:2005 6 21 我也安装了DirectX 9.0C,不过好像没用,玩《地球2160》的时候总是提示说Direct 3D什么的,不懂怎么回是</P>
<P> </P>
<P> </P> |
