应验:Core再创疯狂奇迹,浮点性能Specfp2000暴3000点大关,诛灭Power5
发表于 2006-6-29 12:41:00
原帖由 还在读童话 于 2006-6-29 12:13 发表
不是说扣肉在64位下的性能提升相当有限吗?
这年头居然还有人信pcpop里的文章~~
P.S.
http://www.hardware.fr/articles/ ... -2-duo-dossier.html
发表于 2006-6-29 12:53:00
http://www.spec.org/cpu2000/resu ... 20060613-06201.html
到最后还是Intel的编译器最爽,哈哈。
Montecito 1.6GHz。
SPECfp2000 =  3017
SPECfp_base2000 =  3017
Operating System: Bull Advanced Server 4 (linux kernel 2.6.12 (64k pages), glibc 2.3.4)
Compiler: Intel(R) Fortran Compiler for Linux 9.1 (Build 20060523)
Intel(R) C++ Compiler for Linux 9.1 (Build 20060523)
+FDO: PASS1=-prof_gen  PASS2=-prof_use
Baseline optimization flags:
   C programs:       -fast -ansi_alias -IPF_fp_relaxed +FDO
   Fortran programs: -fast -IPF_fp_relaxed + FDO
Portability Flags:
   178.galgel:  -FI
Peak optimization flags: basepeak=true
The option "maxcpus=0 (ie=UP kernel)" was added to the "elilo.conf"
configuration file in order to invoke a uniprocessor environment.
4 memory boxes, with 8 DIMMs in each
Hardware Vendor: Bull
Model Name: NovaScale 3045 (1600MHz)
CPU: Itanium 2 Processor 9050 1600 MHz FSB 533MHz
CPU MHz: 1600
FPU: Integrated
CPU(s) enabled: 8 cores, 4 chips, 2 cores/chip (Hyper-Threading Technology disabled)
CPU(s) orderable: 1, 2, 3 or 4 (chips)
Parallel: No
Primary Cache: 16KBI + 16KBD on chip per core
Secondary Cache: 1MBI + 256KBD on chip per core
L3 Cache: 12MB (I+D) on chip per core
Other Cache: N/A
Memory: 32 GB (32* 1GB ECC DIMMs DDR2-533 PC4200 533MHZ CL4)
Disk Subsystem: 2*10krpm 73GB SAS disks
发表于 2006-6-29 12:59:00
Montecito的整数性能也不赖,同频性能比较接近Conroe了(输16%):
SPECint2000 =  1474
SPECint_base2000 =  1474
http://www.spec.org/cpu2000/resu ... 20060613-06198.html
Intel Xeon processor 5110 (1066 MHz system bus)
SPECint2000 =  1717
SPECint_base2000 =  1712
http://www.spec.org/cpu2000/resu ... 20060612-06176.html
发表于 2006-6-29 13:07:00
支持Intel Conroe。
有竞争才有发展
希望AMD再接再厉 !#
发表于 2006-6-29 15:06:00
原帖由 Edison 于 2006-6-29 12:31 发表
我从7.x的就开始不断收集intel compiler,9.1的最大改进就是Core2的支持,第一个公开的bulid旧有QxT,之前我在讨论区就发表过这个信息了。
9.1的-fast优化选项集的-qx是-QxP,-QxT不是默认选项,用户可以自 ...
确实奇怪了,v9.1这些测试, 居然都不用-QxT?
也许测试的人也没有注意吧? 或者反而变慢了? 不过变慢应该是没道理。
发表于 2006-6-29 15:12:00
你是QxT用20060323吗? Version 9.1 Build 20060323
发表于 2006-6-29 15:15:00
ICC也有比MSC慢不少的时候。
发表于 2006-6-29 15:16:00
原帖由 RacingPHT 于 2006-6-29 15:15 发表
ICC也有比MSC慢不少的时候。
正确使用,一般不会吧?
发表于 2006-6-29 15:20:00
原帖由 RacingPHT 于 2006-6-29 11:21 发表
Xeon processor 5160 貌似还没"FXxx"贵。
FXxx的价钱确实很Fxxx.
我系穷人 只能用 AMD 的OP 2XX 系列
感情 鹰跳儿  的犯死 都是 大米
