新版 轻轻松松的安装 Linux 系统
发表于 2009-7-30 09:37:59
<< 画面 4-93 >>
________________ SELECTION 1.5 CONFIGURATION _________________
? Selection is a program that allows you to do cut and paste ?
? on the virtual consoles using a mouse. If you choose to ?
? have it run at boot time, the line: ?
? selection -t ms & ?
? will be added to the end of your /etc/rc.d/rc.local. ?
? Running selection with a bus mouse can cause problems with ?
? XFree86 2.0. If XFree86 2.0 refuses to start and complains ?
? that it cannot open the mouse then you might want to comment ?
? the line out of /etc/rc.d/rc.local. Would you like to add ?
? to /etc/rc.d/rc.local so that selection will load at boot ?
? time? ?
_______________________________________________________________
? < Yes > < No > ?
以下主要有三个选择, 假如您的机器摆在 直接 Internet连线,
这时您可以选择 SMTP+BIND, 假如内部 TCP/IP 网路, 可以选用SMTP
, 至於想透过 UUCP通讯, 则选择 UUCP。 安装软体在自动拷贝恰当
的设定档, 并摆在 /etc/sendmail.cf。
<< 画面 4-94 >>
______________________ SENDMAIL CONFIGURATION ______________________?
? Sendmail requires a configuration file (/etc/sendmail.cf). Three ?
? versions are provided: TCP/IP with a nameserver, TCP/IP without ?
? a nameserver, and UUCP. If none of these proves suitable, you ?
? can make your own (look in /usr/src/sendmail). It probably won't ?
? hurt to try one of these, though. ?
? ________________________________________________________________??
?? SMTP+BIND Connected to the net with nameserver access ??
?? SMTP Connected to a network with no nameserver ??
?? UUCP Use UUCP for mail transmission ??
?? SKIP Do not install /etc/sendmail.cf ??
____________________________________________________________________?
? < OK > <Cancel> ?
最後填入时区, 如画面 4-95 的说明。 读者若在台湾的话, 移动
往下方向键, 一直到 ROC, 之後按 <Enter> 键做选择。 请读者特别
留意, 是用放向键移动反白, 不是用空白键。
发表于 2009-7-30 09:38:10
<< 画面 4-95 >>
______ TIMEZONE CONFIGURATION _______
? Select one of the following ?
? timezones: ?
? __________________________________??
?? Australia/LHI ??
?? Australia/NSW ??
?? Australia/North ??
?? Australia/Queensland ??
?? Australia/South ??
?? Australia/Tasmania ??
?? Australia/Victoria ??
?? Australia/West ??
?? Australia/Yancowinna ??
?? Brazil/Acre ??
?? Brazil/DeNoronha ??
?? Brazil/East ??
?? Brazil/West ??
?? Mexico/BajaSur ??
?? Mexico/General ??
?? MET ??
?? ... (画面省略) ??
?? NZ ??
?? Navajo ??
?? PRC ??
?? Poland ??
?? ROC ??
? ____?(+)_________________________ ?
? < OK > <Cancel> ?
<< 画面 4-96 >>
___________________ REPLACE /etc/fstab? ____________________
? You already have an /etc/fstab on your install ?
? partition. If you were just adding software, you ?
? should probably keep your old /etc/fstab. If you've ?
? changed your partitioning scheme, you should use the ?
? new /etc/fstab. Do you want to replace your old ?
? /etc/fstab with the new one? ?
? < Yes > < No > ?
画面 4-96应该是您执行 CONFIGURATION阶段所看到的最後一个画
面, 假如您没有看到这画面, 就表示一定哪里出问题了, 最好您能够
重新执行一遍 CONFIGURATION, 否则通常您也没有办法正常开机进入
系统。 尤其对於安装交大云观 CD-ROM III Linux Plug and Play,
想直接由 CD-ROM 跑 Linux的朋友来说, 若您没有看到画面 4-96 更
新 /etc/fstab 的动作, 您将完全无法启动机器来 Plug & Play :-)
发表于 2009-7-30 09:38:21
以上终於大公告成, 恭喜您, 您就此拥有一部完整的多工多使用
者作业系统, 而且支援完整的 TCP/IP 网路功能。 这里我提一些建议
给新手朋友, 不要期望第一次就可以安装一部没有瑕疵的 Linux 系统
,照笔者经验, 很多新手们问一些奇奇怪怪的问题, 这类的问题有很多
都是起因於安装过程的错误。
最後, 回到主服务画面, 底下我们可以 <EXIT> 离开, 之後用
reboot 指令重新开机, 且注意, 用刚刚您造出来的系统开机磁片来启
动。
<< 画面 4-97 >>
______________ Slackware Linux Setup (version FD-2.0.2) ______________?
? Welcome to Slackware Linux Setup. ?
? Select an option below using the UP/DOWN keys and SPACE or ENTER. ?
? Alternate keys may also be used: '+', '-', and TAB. ?
? __________________________________________________________________??
??HELP Read the Slackware Setup HELP file ??
??KEYMAP Remap your keyboard if you're not using a US one ??
??QUICK Choose quick or verbose install mode [now: VERBOSE] ??
??MAKE TAGS Experts may customize tagfiles to preselect packages ??
??ADDSWAP Set up your swap partition(s) ??
??TARGET Set up your target partitions ??
??SOURCE Select source media ??
??DISK SETS Decide which disk sets you wish to install ??
??INSTALL Install selected disk sets ??
??CONFIGURE Reconfigure your Linux system ??
??EXIT Exit Slackware Linux Setup ??
?_____________________________________________________________________?
? < OK > <Cancel> ?
______________________________________________________________________?
发表于 2009-7-30 09:38:31
第五章 其他非标准安装程序解析
透过前几章的介绍, 您应该已经大致完成 Slackware Linux 的
系统安装了。 本章介绍的话题, 主要是一些与系统安装有直接或间
接关系的技术与观念, 相信这些可以帮助您进一步了解 Linux。 笔
者也再次提醒, 对於想把 Linux 摆在严肃场合的朋友来说, 若没有
把握系统安装的品质, 不妨考虑重新安装, 而透过更多的技术琢磨,
重新安装後的系统必然可以更顺畅运转。
交大『云观 CD-ROM III』直接由 CD-ROM执行之安装法
bootdisk 磁片可以当作系统急救磁片
如何自制 bootdisk
pkgtool 软体维护
手工建置档案系统
您需要虚拟记忆体吗?
手工建造 Swap Partition
手工建造 Swap File
手工设定 LILO
如何解除LILO自动开机程序
□ 交大『云观 CD-ROM III』直接由 CD-ROM执行之安装法
笔者很高兴看到交大一群朋友们的努力, 出版了一份本土的 "Plug
& Play" Linux CD-ROM, 我想, 凡是受益於这份 CD-ROM 的朋友, 应
该有必要知道, 这 CD-ROM 主要是刘大川⒒平缒炯幄⒗钚??⒗罱
达以及张杰生等几位先生先进们的努力所成就。
由於本 CD-ROM 也附有标准 Slackware Linux 2.1.0, 想正常安
装 Linux 系统者 (其实这才是笔者所推荐的, 本节的 Play & Play
Linux 我感觉只适合用来作为 demo 用途, 不过这算是笔者的偏见而
已), 请叁考第四章的说明即可, 不过, 仍有一点须要注意的, 就是
CD-ROM 上的路径, 这部份您要回答 〃/slackware/slakware〃 (注
意不要拼错字) 即可, 也就是在 setup 画面选择 "slackware/slakware
TransAmeritech CD" 选项。
这一节我们所要介绍的, 是此次交大 云观三的一个特色之一 --
Plug & Play, 这意思是说, 好像电器用品一样, 插上电源就可以玩了,
虽然, 这样说法或许有些夸张, 其真正的情况是说, 您「几乎」 不需
要额外的进行正常的安装程序, 而只需要一些些硬碟空间, 以及几步简
单的程序, 之後, 就可以直接从 CD-ROM 上跑 Linux!
底下我们就来看看如何把 Linux 插上去就可以玩 :-)
一样的, 我仍然建议读者先给 Linux 预备一个专有分割区 (
Partition) [注], 这个分割区不需要很大, 根据笔者测试, 大约只需
要 13MB 到 15MB 空间即可进行安装, 而安装後系统实际占用空间大
约为 10MB左右。
有了一个分割区, 接下来的动作当然是建置档案系统, 这就好像
DOS 的 FORMAT (格式化) 动作。 以上两个动作, 仍然是标准的作业
系统安装步骤, 以下的步骤才是特殊之处。
前面几段话已经暗示了, 我们其实没有办法把 Linux 直接在云观
III CD-ROM 上跑, 真正的情况, 是云观 III CD-ROM 设计了一个 /usr
目录, 这目录收集了高达二百六十几MB的应用软体, 这些都是可立刻
执行的, 也就是说可以把 CD-ROM 的 /cdrom/usr目录 挂在 / 档案系
统之下的 /usr。 我们反过来说, 我们之前之所以要设立一个 13MB的
分割区, 是因为 Linux 系统的 / (root) 档案系统仍然必须设立好,
且 / 档案系统下的 /bin /sbin/ /etc /boot /proc /tmp
等等目录架构是构成一部 Linux系统所必须有的, 这些虽然可以精简阳
春, 可是却不能没有, 更重要的原因, Linux / 档案系统有一部份是必
须可以读也可以写 (Read & Write), 而 CD-ROM 却只能唯读 (Read Only
发表于 2009-7-30 09:38:44
云观 III CD-ROM 所谓 Play & Play的设计, 就是把以上所提到的
这些最基本档案系统, 事先压缩成两个独立的档案, 放在该 CD-ROM 内
(/cdrom/linux/root.tgz 及 /cdrom/linux/var/tgz), 所以说, 我们
安装时, 在观念上, 就是直接把这两个档案直接解压缩在这一个 13MB
的分割区上, 该分割区就立刻拥有一个完整的档案系统架构。 这里,
我们可以容易的看出, 这样的安装法完全不同於标准 Slackware Linux
安装程序。
经过了直接的解压缩安装, 我们仍然需要非常简单的系统设定,
而这部份又与 Slackware Linux安装程序完全一样, 於是我们可以完
全引用 setup 程式来做, 不过主要只做 setup 里面的 SOURCE 与
CONFIGURATION两道步骤。 当这到步骤也完成之後, 我们重新开机,
这时, 我们可以看到系统一启动过程中, CD-ROM 灯号就立刻亮起来,
而且断断续续, 这是因为系统决大部分的东西都放在该 CD-ROM 内,
系统必须依靠 CD-ROM 才可以完整启动机器, 更重要的, 我们所需
要的所有应用软体, 也都摆在该 CD-ROM内。
希望以上罗哩罗唆的说明, 有助於观念上的补充, 以下, 我们就
来看看实际上的操作细节。
步骤零, 分割区规划:
首先您要根据第四章的说明, 规划出至少 13MB 的硬碟空间, 再
次提醒您, 您必须在 Linux 环境下用 fdisk 来执行规划, 更具体的
说, 是用 bootdisk及rootdisk两张磁片开机後 (有关bootdisk 及
rootdisk 的选择与制作, 请叁考第三章), 执行 fdisk。
步骤一, 建置作档案档案系统:
假如想依照 Slackware Linux的标准程序来做的话, 可以叁考第
四章的说明, 假如想迅速的手工操作的话, 可以叁考第五章「手工建
置档案系统」乙节的说明。
以上两个步骤都可以用 Slackware Linux的 setup 标准安装程序
来完成。
接下来的步骤才是本节的精华, 以下我们要做一些假设, 我们假
设所要安装的分割区为 /dev/hda2, 使用之 CD-ROM 为 Panasonic
562B/563B, 读者引用时, 记得依照您的实际情况做修改。
步骤二. 安装前预备
以下步骤类似於 Slackware Linux setup 过程中, 所指令的 Target
与 Source等程序。
往下的步骤, 您也同样选用恰当的 bootdisk 及 rootdisk 磁片
来启动机器, 之後以 root 帐号进入系统, 接下来执行以下操作。
$ mount -t ext2 /dev/hda2 /mnt -o rw
这步骤与 Slackware Linux setup 程序的 Target 设定同样意思。
$ mount -t iso9660 /dev/sbpcd /var/adm/mount -o ro
这步骤与 Slackware Linux setup 程序的 Source 设定同样意思。 请
读者特别留意, 假如您使用 Mitsumi 唯独光碟机, 把 /dev/sbpcd
换成 /dev/mcd, 是 Sony CDU-31A 的话换成 /dev/sonycd, 是 Sony
CDU-535 的话换成 /dev/cdu535, 是 LMS/Philips 则换成 /dev/lmscd
, 其他 SCSI 唯读光碟机则换成 /dev/scd0。
发表于 2009-7-30 09:38:59
步骤三. Linux Plug & Play 安装:
$ cd /cdrom/linux
$ install
正常的话, 您会在萤幕上看到一连串档案拷贝的过程, 这步骤可
能维持一两分钟。
步骤四. 系统设定
这步骤您也可以引用 Slackware Linux 的 setup 标准安装程序
来完成, 不过大约有两点要留意, 在 setup 程序中, 只执行 SOURCE
以及 CONFIGURATION两到程序即可, TARGET 不执行是因为刚刚步骤
二时已经完成, SOURCE之所以要重复做一次 (注意, 步骤二也同样已
经做了), 我发现是因为 setup 会 umount 已经挂好的光碟机。
$ setup
这个指令就是您此刻唯一需要做的, 请叁考第四章的说明, 细心
的完成 CONFIGURATION 的操作, 之後用 CONFIGURATION过程中所制
作的开机片重新启动机器。 正常的话, 您就可以使用这 Plug & Play
Linux。
注. Linux 也可以在 UMSDOS模式下, 直接在 DOS Partition下执行,
但笔者不推荐这样做, 尤其想把 Linux摆在有生产力应用所在者, 不
要试。
□ bootdisk 磁片可以当作系统急救磁片
这一章中, 我们首先来看看 bootdisk 作为救急磁片的用途。
Slackware Linux 的 bootdisk 的第一个救急用途, 就是用来
启动硬碟内的 Linux 系统, 什麽时候需要用到呢? 比方说您原本
从硬碟开机突然失效了, 更不巧您也没有做软碟开机片, 这些情况
您就可以使用 bootdisk 开机 (没有用到 rootdisk 磁片), 之後
在提示符号下使用 mount root=/dev/hda1 指令, 详细情况如下面
萤幕所示。
LILO
Welcome to the Slackware Linux 2.0.2 Bootkernel disk!
If you have any extra parameters to pass to the kernel, enter them at the
prompt below. For instance, you might need something like this to detect the
hard drive on PS/1 and ValuePoint models from IBM:
ramdisk hd=cyl,hds,secs (Where "cyl", "hds", and "secs" are the number of
cylinders, sectors, and heads on the drive. Most
machine won't need this.)
Also, in a pinch, you can boot your system with a command like:
On machines with low memory, you can mount root=/dev/fd1 or
mount root=/dev/fd0 to install without a ramdisk. See LOWMEM.TXT for details.
If you wold rather load the root/install disk from your second floppy drive:
drive2 (or even this: ramdisk root=/dev/hd1)
DON'T SWITCH ANY DISKS YET! This prompt is just for entering extra paramters.
If you don't need to enter any paramters, hit ENTER to conitnue.
boot: mount root=/dev/hda1
发表于 2009-7-30 09:39:14
把上面 /dev/hda1 换成您实际的情况就可以。
Slackware Linux bootdisk/rootdisk 组合也可以作为系统急救
磁片, 比方说您不小心修改 /etc/fstab 档案, 但却由於有错误造成
无法开机, 类似这种例子, 您就可以用 bootdisk 磁片开机, 之後换
插入 rootdisk磁片, 继续执行开机作业, 我们前面提很多次, 这样子
执行的就是一套阳春的 Linux作业系统, 但虽然阳春, 基本的系统工
具程式都有, 比方说 vi 文字编辑器。
由这软碟系统来修复硬碟内的 Linux档案系统的作法, 是先把硬
碟内的 Linux / (root) 档案系统挂上来, 之後用 vi 修改造成错误
的设定档案, 或者用 e2fsck 或 fsck 来修复硬碟内的档案系统结构
(就类似 DOS的 CHKDSK指令)。
笔者发现 Slackware Linux 2.02 以後的 rootdisk 磁片里面已
经没有 vi 及 e2fsck 等工具, 假如您想使用 vi 的话, 可以试看看
/mnt/usr/bin/vi。
□ 如何自制 bootdisk
有些朋友会碰到 bootdisk 磁片开机後, 无法认为电脑硬体设备,
举个例子来说, 比方您电脑配备有一个非常特别品牌的硬碟控制卡,
而所以现有 Slackware Linux 的众多 bootdisk 都没有 driver, 而
您又确定知道新版的 Linux Kernel source 里面有 driver。 您有
这情况时, 可以请别人帮忙, 在别一部 Linux 机器上编译该份 Kernel
核心程式码, 之後根据该份核心码制作一张您自己的 bootdisk。
自制 bootdisk 的操作, 实际上是拿一片已经制作好的 bootdisk
磁片, 把该磁片挂 (Mount) 一部运转中的 Linux 系统下, 之後把我
们事先编译好的系统核心拷贝到磁片上, 这样会把磁片上旧核心盖过
去, 最後, 再执行一些开机设定动作就可以了。 细节如下:
0. 编译系统核心, 把所需要的Driver编译进去
(请叁考拙着『轻轻松松管理 Linux/Unix』)
1. 插入一张已经制作好的 bootdisk 磁片
2. mount /dev/fd0 /mnt # 挂上 bootdisk
3. cat zImage > /mnt/vmlinuz # 取代 bootdisk上旧 Kernel
4 rdev -R /mnt/vmlinuz 0 # 指定 bootdisk 开机後可读写
5. rdev /mnt/vmlinuz /dev/fd0H1440
# 指定 开机後 root (/) 档案系统所在, 此处假设 A: 为三寸半磁碟
# 机。 若是5 1/4寸 1.2MB磁碟, 则改为 /dev/fd0h1200
6. rdev -r /mnt/vmlinuz 1440
# 指定 RAMDISK大小, 若是 1.2MB磁片, 可以改为 1200
7. cp -fa /boot/* /mnt/boot # 拷贝自己系统下的开机相关档案
8. lilo -r /mnt # 重新安装 LILO 软碟开机, 萤
Added ramdisk # 幕上会看到 这三行讯息
Added drive2
Added mount
9. umount /mnt
A. 完成, 取出您的磁片, 这就是一张自制的 bootdisk磁片
发表于 2009-7-30 09:39:26
□ pkgtool 软体维护
有时候, 您因为任何原因, 需要增减系统内的应用软体, 有这情
况时您就必须借助 pkgtool 的帮忙。 比方说, 您想把某一个不常使
用的软体拿掉, 因为它占用非常大的硬碟空间, 或者比方说, 一开始
时, 您只安装了最基本的A 与 AP系列软体, 您後来想要加装剩下一系
列的软体, 这时您就可以使用 pkgtool 程式来达成。
pkgtool 的使用场合主要是在安装完成後的系统之下, 而不是
bootdisk/rootdisk 所执行的安装过程中。
pkgtool 的使用法非常简单, 这部份笔者在这『轻轻松松管理
Linux/Unix』 这本书也有提到。 大体而言, 您只需要下 pkgtool
这指令, 就可以直接在萤幕画面上得知操作的细节, 应该非常容易。
□ 手工建置档案系统
在第四章中, 我们提到, 执行作业系统的安装过程中, 必然要经
过一道「建置档案系统」的程序 (DOS用 FORMAT, Linux用 mke2fs),
这道程序是用来把已经完成规划的分割区, 进一步赋予其档案系统属
性。
可惜前面的介绍中, 由於 setup 自动的进行这道步骤, 所以我们
没有认识到如何收工来做这样工作, 这一节就要补充这个不足。
作法上, 通常我们必须先规划出一个新个分割区 (或者说已经规
划好了), 我们接着要想办法知道要所执行档案系统建置的分割区其实
际的大小 (Bloack数目), 以下例子是用 fdisk 来取得数据。
发表于 2009-7-30 09:39:38
# fdisk /dev/hdb
Command (m for help): p
Disk /dev/hdb: 16 heads, 63 sectors, 826 cylinders
Units = cylinders of 1008 * 512 bytes
Device Boot Begin Start End Blocks Id System
/dev/hdb1 1 1 100 50368+ 83 Linux native
/dev/hdb2 101 101 405 153720 7 OS/2 HPFS
/dev/hdb3 536 536 736 101304 83 Linux native
/dev/hdb4 * 406 406 535 65520 a5 BSD/386
Command (m for help): q
假如我们的目的分割区为 /dev/hdb3, 这时我们看其对应那一行,
得到一个数据 101304 Bloacks, 根据这数据, 我们执行以下指令:
$ mke2fs -c /dev/hdb3 101304
我们就简单介绍如此, 想深入认识的朋友, 可以用 man mke2fs
指令来查询线上使用手册。
□ 您需要虚拟记忆体吗?
在前面第四章中, 我们介绍到很多地方提起「虚拟记忆体」, 您
心理会不会问说, 「我真的需要设计虚拟记忆体吗」?
这问题牵涉到一个实际的问题, 就是您现有的记忆体够大吗? 大
凡实际的记忆体不够时, Linux 便有可能开始用到虚拟记忆体, 假如
这时候连虚拟记忆体也用光了, 系统便会有类似当机的反应 (多半不
会真正当机), 至少正执行中的应用软体因此原因当掉的可能非常大。
照笔者经验, 我通常会规划一个 Swap Partition 的虚拟记忆体,
而其大小不小於实际虚拟记忆体之大小, 以这样的情况观察系统的运
转, 尤其是记忆体消耗的情况, 若发觉有需要, 可以再设立第二个
Swap Partition, 若没有办法增加 Swap Partition, 可以用 Swap
File, 不过 Swap File 效率上比 Swap Partition 低。
最後提醒读者一个观念, 假如系统经常性的使用掉大量的虚拟记
忆体, 这时您或许就该考虑扩充实际的记忆体了, 假如您希望系统运
转的效率处在最佳状态的话。 对於把 Linux使用在有严肃生产力场合
的读者朋友来说, 尤其要注意这一点。
发表于 2009-7-30 09:40:03
□ 手工建造 Swap Partition
手工建造一个 Swap Partition 作为虚拟记忆体, 操作上非常简
单, 我们同样是用 fdisk 规划出一个新的分割区 (假设硬碟内仍未
满), 同时把该分割区的型别改别 Swap Partition, 之後我们用 mkswap
指令赋予其档案系统属性, 最後, 用 swapon 指令启动使用就可以。
一共三道步骤。
以下我们就来看一下实际操作系范例。
步骤一.
/# fdisk /dev/hda ← 在Shell提示符号後键入fdisk指令
Command (m for help): p ← 我先来看看目前的设定情况
Disk /dev/hda: 15 heads, 17 sectors, 1001 cylinders
Units = cylinders of 255 * 512 bytes
/dev/hda1 * 1 1 161 20519 4 DOS 16-bit <32M
/dev/hda2 302 302 1001 89250 81 Linux/MINIX
/dev/hda3 260 260 301 5355 81 Linux/MINIX
Command (m for help): n ← 增加一个Partition
Command action
e extended
p primary partition (1-4)
p ← 指定Primary
Partition number (1-4): 4 ← 指定第四个分割区 (前三个已经满了)
First cylinder (162-1001): 162 ← 回答162 (162为系统自动侦测得知)
Last cylinder or +size or +sizeM or +sizeK (162-259): 259 ←
259也是系统自动侦测, 这两个数据, 您依照自己情况调整
Command (m for help): t ← t 变更分割区的 ID
Partition number (1-4): 4 ← 第4个分割区 (您依照情况调整)
Hex code (type L to list codes): 82 ← 82代表Swap Partition
Changed system type of partition 4 to 82 (Linux swap)
Command (m for help): p ← 设定完毕, 我们先瞧一瞧
/dev/hda4 162 162 259 12495 82 Linux swap
果然新造一个/dev/hda4 partition, 且指定为Linux Swap
Command (m for help): w ← 无误後, 将以上设定存起来
The partition table has been altered.
Please reboot before doing anything else.
步骤二.
执行步骤一後, 重新开机, 接着执行步骤二及步骤三。
$ mkswap -c /dev/hda4 12495 ← 这里 /dev/hda4为刚设定的Swap
Partition, 12495为该分割区的大小
Setting up swapspace, size = 12787712 bytes
